Problem after upgrading from 4.2 to 4.2.2
gary.whitaker
I just recently did an upgrade from 4.2 to 4.2.2 running on an Appliance. After the upgrade all the services do not load up. Running a "show app status LMS" always comes up with a message saying daemon manager is not fully intialized. The DCRServer process is just hanging with the status "waiting to initialize".
I am able to GUI in but can't use view any of the managed devices due to DCRServer in a hung state. I have restared LMS application multiple times. I have stopped LMS application and then reloaded the box. The issue still keeps occuring, im going to raise a TAC case but was wondering if anyone else has come across this issue?
AFROJ AHMAD
Are you still facing the above issue ?
If yes send me the below information.
output of pdshow
ctm_config.txt  from the below location:
NMSROOT\CSCOpx\MDC\tomcat\lib
NMSROOT\CSCOpx\MDC\tomcat\shared\lib
NMSROOT\CSCOpx\MDC\tomcat\webapps\cwhp\WEB-INF\lib
Also md.properties and Regdaemon.xml
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
