02-18-2021 10:20 AM
I have problem with my DHCP betwen AP3700E, switch SG300 and router 890sfp.
My router is configured as a DHCP server and here is the configuration :
no aaa new-model
ip dhcp excluded-address 190.160.254.1 190.160.254.50
ip dhcp excluded-address 192.168.10.1 192.168.10.50
ip dhcp pool LocalDHCP
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 192.168.10.1
ip dhcp pool vlan 2
network 190.160.254.0 255.255.255.0
dns-server 190.160.254.1
default-router 190.160.254.1
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
cts logging verbose
license udi pid C892FSP-K9 sn FJC2027L16W
license accept end user agreement
license boot module c800 level advsecurity
username MYNAME privilege 15 secret 5 $1$sbDR$yVmwrsO8DcFiJYL3qweBR/
interface GigabitEthernet0
no ip address
spanning-tree portfast
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
switchport access vlan 2
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
no ip address
duplex auto
speed auto
interface GigabitEthernet9
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface Vlan2
ip address 190.160.254.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source list 1 interface GigabitEthernet9 overload
ip nat inside source list 2 interface GigabitEthernet9 overload
snmp-server community public RO
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 2 permit 190.160.254.0 0.0.0.255
This is my configuration of the Switch SG300
vlan database
vlan 2
exit
hostname switch3ac595
username cisco password encrypted 737fe58f8b863cfdcdf56a1f7c773eae00e0947b privilege 15
interface gigabitethernet1
switchport mode access
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet12
interface gigabitethernet13
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
interface gigabitethernet18
interface gigabitethernet19
interface gigabitethernet20
interface gigabitethernet21
interface gigabitethernet22
interface gigabitethernet23
interface gigabitethernet24
interface gigabitethernet25
interface gigabitethernet26
interface gigabitethernet27
interface gigabitethernet28
interface gigabitethernet29
interface gigabitethernet30
interface gigabitethernet31
interface gigabitethernet32
interface gigabitethernet33
interface gigabitethernet34
interface gigabitethernet35
interface gigabitethernet36
interface gigabitethernet37
interface gigabitethernet38
interface gigabitethernet39
interface gigabitethernet40
interface gigabitethernet41
interface gigabitethernet42
interface gigabitethernet43
interface gigabitethernet44
interface gigabitethernet45
interface gigabitethernet46
interface gigabitethernet47
interface gigabitethernet48
interface gigabitethernet49
switchport trunk allowed vlan add 2
interface gigabitethernet50
interface gigabitethernet51
interface gigabitethernet52
Exit
This is my configuration of the AP3700E
no aaa new-model
no ip source-route
no ip cef
dot11 syslog
dot11 vlan-name CMEI vlan 1
dot11 vlan-name CMEI-Patient vlan 2
dot11 ssid CMEI
vlan 1
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii 7 05535E5779181A5D4D
dot11 ssid CMEI-Patient
vlan 2
authentication open
guest-mode
mbssid guest-mode
wpa-psk ascii 7 025E5C0353525B7518
dot11 guest
username Cisco privilege 15 password 7 05280F1C2243
bridge irb
interface Dot11Radio0
no ip address
encryption vlan 2 mode ciphers aes-ccm
ssid CMEI-Patient
antenna gain 0
stbc
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 2
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Dot11Radio1
no ip address
encryption vlan 1 mode ciphers aes-ccm
ssid CMEI
antenna gain 0
peakdetect
dfs band 3 block
stbc
mbssid
channel dfs
station-role root
interface Dot11Radio1.1
encapsulation dot1Q 1 native
bridge-group 1
no ip address
duplex auto
speed auto
interface GigabitEthernet0.1
bridge-group 1
interface GigabitEthernet0.2
bridge-group 2
interface BVI1
mac-address 00f6.6344.d76c
ip address 192.168.10.6 255.255.255.0
ipv6 address dhcp
ipv6 address autoconfig
ip default-gateway 192.168.10.1
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip route 0.0.0.0 0.0.0.0 192.168.10.1
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
here is my physical connection
Router Ge 0 to switch Gi 49 (trunk)
Router Ge 7 to switch Gi 50 (trunk)
Router Ge 9 to FAI
AP3700 to switch Gi 1
My computer to switch Gi 2
Om my computer i receive an IP Address ,but with WIFI i do not receive anything.
thanks
02-18-2021 01:18 PM
Would you post the output on the switch for the command show interface trunk?
You tell us that
but Ge0 is an access port in vlan 1
but Ge7 is an access port in vlan 2
Remember that access ports send Ethernet frames that have no vlan tag. So if the switch port is a trunk and receives a frame with no tag it will treat it as belonging to vlan 1.
Also you tell us
but Gi1 is an access port in vlan 1. The AP expects to be connected to a trunk port.
It is not related to the main issue with the AP but I would point out this
I would suggest that rather than 2 nat statements with 2 access lists that you configure a single access list with 2 permit statements and have a single nat statement.
