problem in cisco works
ahmedhammouche
hi,
i have cisco works with these versions:
versions of LMS
-campus manager 5.2.0
-cisco view 6.1.9
-cisco works assistant 1.2.0
-cisco works common services 3.3.0
-device fault manager 3.2.0
-integration utility 1.9.0
-internet work performance monitor 4.2.0
-LMS portal 1.2.0
-Ressource manager essentials 4.3.0
it works fine but now i have a problem in daemon manager could not be start
c:\>net start crmdmgtd
The CiscoWorks Daemon Manager service is starting.
The CiscoWorks Daemon Manager service could not be started.
The service did not report an error.
More help is available by typing NET HELPMSG 3534.
c:\>pdshow
ERROR: connect to dmgtd process on "127.0.0.1" on port 42340 failed:
Vinod Arya
I guess this is duplicate post, per thread :
https://supportforums.cisco.com/thread/2191023
I dont think you have updated the LMS version to 3.2.1, as recommended, post screenshot of :
LMS > CS > Software Centre > Device Update
if not updated, as suggested, you can get the patch from Cisco TAC team, by opening a case.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
I apologize, I meant screenshot of #
LMS > CS > Software Centre > Software Update
-Thanks
this is software update
Products Installed
Showing 1-9 of 9 records
Product  Name Version  With Patch Level Installed  Date
1.Campus  Manager5.2.006 Dec 2010, 22:08:42 WAT
2.CiscoView6.1.906 Dec 2010, 22:08:42 WAT
3.CiscoWorks  Assistant1.2.006 Dec 2010, 22:08:42 WAT
4.CiscoWorks  Common Services3.3.006 Dec 2010, 22:08:42 WAT
5.Device Fault  Manager3.2.006 Dec 2010, 22:08:43 WAT
6.Integration  Utility1.9.006 Dec 2010, 22:08:43 WAT
7.Internetwork Performance Monitor4.2.006 Dec 2010, 22:08:43 WAT
8.LMS Portal1.2.006 Dec 2010, 22:08:44 WAT
9.Resource  Manager Essentials4.3.006 Dec 2010, 22:08:44 WAT
