Problem with CiscoView
Plinio Brandao
Level 3
Level 3
Hi People,
My name is Plinio and i'm from Brazil. I'm configuring the CiscoWorks in my job, but i'm having some problems with CiscoView.
Everything is working fine, but when i try use the resource CiscoView, i recieve the message 404 Not found.
What should be? Some informations:
- SO Windows 2003 x64bits;
- CiscoWorks and complements versions in picture attached;
- Something related with the file chassis.do? I can't find it in the directory CVng/chassis.do.
- I already tried to re-install the full CiscoWorks and the CiscoView stand alone, but without success;
That's all. I hope get help with you.
Best regards!
Plinio
CiscoView is not properly installed, and I'm not sure I would trust the rest of the installation.  Completely uninstall LMS, then reboot.  Then follow the guidelines at https://supportforums.cisco.com/docs/DOC-9132 to reinstall it.
12 Replies 12
Joe Clarke
Did you recently change the hostname of this server?
Hi Joe,
The hostname of the server wasn't changed. I tried using the hostname instead of ip address and received the message attached.
Suggestions?
About the file chassis.do that's missing, is it normal?
I can't find the file anywhere.
When you login to CiscoWorks, what URL do you see in the location bar?
Hi Joe,
After login, appears this url: https://gn216cb-new/cwportal/group/lms/lms-functional
See the attachement.
Thank you!
It doesn't appear that you installed CiscoView.  If you had, there would be a portlet on the Functional View called CiscoView.  When you installed LMS, what did you select from the components list?
Hi Joe,
In the first time, i selected everything. After, i instaled just the CiscoView. In the LMS, we can see the version of the CiscoView instaled.
Some procedure should i take during the install?
What directories do you have under NMSROOT/MDC/tomcat/webapps?
Joe,
See the file.
Thank you.
Post the NMSROOT/MDC/tomcat/conf/server.xml file.
Hi Joe,
See the file please.
Hi Joe,
We had some problems with our machine. We will try to reinstall the LMS. So, when i finished, i post the results here.
thank you for the help.
Best regards.
