problem with implemanting eem track for ip sla
ran.malevsky
hi
i'm trying to implement a track for is sla
which will put a notice (later i will change it to restart the interface) on screen
the tracking is working however the applet doesn't recognize the state change
below are config and logging
do  you see a mistake?
what am i doing wrong?
thanks
ran
config
1.my ip sla config is :
ip sla 2
icmp-echo 1.1.1.1 source-interface Loopback1
ip sla schedule 2 life forever start-time after 00:00:05
2. my track config is :
track 1 ip sla 2 reachability
track 3 ip sla 2
3. my eem applets are :
event manager applet lostcell
event track 1 state down
action 1.0 puts "cellular_is-down"
action 2.0 end
event manager applet cell3
event track 3 state down
action 1.0 puts "cellular3"
action 2.0 end
some sh and tell
clear logg
sh track brief
Track   Object                           Parameter        Value Last Change
1       ip sla      2                    reachability     Up    00:03:07
2       ip route    1.1.1.1/24           reachability     Down  01:05:54
3       ip sla      2                    state            Up    00:03:07
conf t
int cell 0
sh
end
sh track brief
1       ip sla      2                    reachability     Down  00:00:00
2       ip route    1.1.1.1/24           reachability     Down  01:06:48
3       ip sla      2                    state            Down  00:00:00
sh logg (from interface shut)
.Jun  7 10:08:14.410: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
.Jun  7 10:08:14.410: fh_fd_syslog_event_match: num_matches = 0
.Jun  7 10:08:14.410: fh_fd_data_syslog: num_matches = 0
.Jun  7 10:08:23.606: cli_history_entry_add: free_hist_list size=0, hist_list size=7
.Jun  7 10:08:23.606: check_eem_cli_policy_handler: command_string=show track brief
.Jun  7 10:08:23.606: check_eem_cli_policy_handler: num_matches = 0, response_code = 1
.Jun  7 10:08:34.763: cli_history_entry_add: free_hist_list size=0, hist_list size=7
.Jun  7 10:08:34.763: check_eem_cli_policy_handler: command_string=show track brief
.Jun  7 10:08:34.763: check_eem_cli_policy_handler: num_matches = 0, response_code = 1
.Jun  7 10:08:36.935: cli_history_entry_add: free_hist_list size=0, hist_list size=7
.Jun  7 10:08:36.935: check_eem_cli_policy_handler: command_string=show track brief
.Jun  7 10:08:36.935: check_eem_cli_policy_handler: num_matches = 0, response_code = 1
.Jun  7 10:08:38.095: cli_history_entry_add: free_hist_list size=0, hist_list size=7
.Jun  7 10:08:38.095: check_eem_cli_policy_handler: command_string=show track brief
.Jun  7 10:08:38.095: check_eem_cli_policy_handler: num_matches = 0, response_code = 1
.Jun  7 10:08:44.479: %TRACKING-5-STATE: 3 ip sla 2 state Up->Down
.Jun  7 10:08:44.479: %TRACKING-5-STATE: 1 ip sla 2 reachability Up->Down
.Jun  7 10:08:44.479: fh_fd_syslog_event_match: num_matches = 0
.Jun  7 10:08:44.479: fh_fd_data_syslog: num_matches = 0
.Jun  7 10:08:45.011: cli_history_entry_add: free_hist_list size=0, hist_list size=7
.Jun  7 10:08:45.011: check_eem_cli_policy_handler: command_string=show track brief
.Jun  7 10:08:45.011: check_eem_cli_policy_handler: num_matches = 0, response_code = 1
.Jun  7 10:09:00.003: fh_fd_timer_process_async
.Jun  7 10:09:00.003: cron_tick: num_matches 0
.Jun  7 10:09:01.819: cli_history_entry_add: free_hist_list size=0, hist_list size=7
.Jun  7 10:09:01.819: check_eem_cli_policy_handler: command_string=show logging
.Jun  7 10:09:01.819: check_eem_cli_policy_handler: num_matches = 0, response_code = 1
.Jun  7 10:10:00.004: fh_fd_timer_process_async
.Jun  7 10:10:00.004: cron_tick: num_matches 0
.Jun  7 10:11:00.005: fh_fd_timer_process_async
.Jun  7 10:11:00.005: cron_tick: num_matches 0
.Jun  7 10:12:00.002: fh_fd_timer_process_async
Your policies didn't register.  Try:
no event manager applet lostcell
action 1.0 syslog msg "cellular is down"
no event manager applet cell3
action 1.0 syslog msg "cellular3"
What version of IOS is this?
5 Replies 5
Joe Clarke
I don't see any problem with the applets (other than not needing an "end" action).  The puts should go to syslog, but you might try changing the puts action to a syslog action:
Post the output of "show event manager policy registered" and "show event manager history event"
ok
it looks like nothing is running
the lines return empty
any clues?
sh track brief
1       ip sla      2                    reachability     Up    00:01:59
2       ip route    1.1.1.1/24           reachability     Down  00:04:12
3       ip sla      2                    state            Up    00:01:59
sh track brief
2       ip route    1.1.1.1/24           reachability     Down  00:04:13
sh event manager policy registered
No.  Class     Type    Event Type          Trap  Time Registered           Name
sh event manager history events
No.  Job Id Proc Status   Time of Event            Event Type        Name
*Jun  8 08:07:01.607: %LINK-5-CHANGED: Interface Cellular0, changed state to administratively down
*Jun  8 08:07:03.503: %SYS-5-CONFIG_I: Configured from console by console
*Jun  8 08:07:16.331: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
*Jun  8 08:07:48.880: %TRACKING-5-STATE: 3 ip sla 2 state Up->Down
*Jun  8 08:07:48.880: %TRACKING-5-STATE: 1 ip sla 2 reachability Up->Down
*Jun  8 08:13:34.865: cli_history_entry_add: free_hist_list size=0, hist_list size=7
*Jun  8 08:13:34.865: check_eem_cli_policy_handler: command_string=show logging
*Jun  8 08:13:34.865: check_eem_cli_policy_handler: num_matches = 0, response_code = 1
*Jun  8 08:14:00.002: fh_fd_timer_process_async
*Jun  8 08:14:00.002: cron_tick: num_matches 0
*Jun  8 08:14:07.526: cli_history_entry_add: free_hist_list size=0, hist_list size=7
*Jun  8 08:14:07.526: check_eem_cli_policy_handler: command_string=show clock
*Jun  8 08:14:07.526: check_eem_cli_policy_handler: num_matches = 0, response_code = 1
*Jun  8 08:14:13.382: cli_history_entry_add: free_hist_list size=0, hist_list size=7
*Jun  8 08:14:13.382: check_eem_cli_policy_handler: command_string=show logging
*Jun  8 08:14:13.382: check_eem_cli_policy_handler: num_matches = 0, response_code = 1
it worked
did the
no event manager ...
thanks
what do you think was the cause?
by the way
Version 15.1(1)T1, RELEASE SOFTWARE (fc2)
thanks again
ran
I think that "end" was bogus.  The end action is for terminating a control or condition block.
