11-12-2015 09:57 PM
hi
sorry for the rookie question
configuring an ASA and having issue getting it set up.
We're putting this in place between our subnet and the office wifi router (hence the strange outside IP
can ping ok from outside to 192.168.1.1
but cannot from inside - when i run ping from ASDM i receive;
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Error: inside interface is shutdown
Success rate is 0 percent (0/1)
just did the basic config from startup wizard
Running ASDM 7.1, ASA 9.1(3)
config
: Saved
ASA Version 9.1(3)
hostname CAP-FW-SG
enable password zCaMpE8Kjt0Brwxi encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.210.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 192.168.1.254 255.255.255.0
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) dynamic interface
nat (inside,outside) after-auto source dynamic any interface
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-reco
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.1.0 255.255.255.0 outside
http 192.168.210.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.210.50-192.168.210
dhcpd dns 8.8.8.8 4.4.4.4 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username capadmin password Xlctwl8SJ1l/ahc6 encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:79073ffe0ee
: end
please help where i'm going wrong
thanks
11-13-2015 10:27 AM
Hi stoo12009,
The error states " inside interface is shutdown". Seems like you do not have any connection from internal subnet to inside interface.
Please plug a cable into inside interface from internal device (switch) and run "no shut" under "interface e0/x" where you plug the cable.
Verify the interface is up via "show interface ip brief" command.
Feel free to ping if it does not help.
Dinesh Moudgil
P.S. Please rate helpful posts.
