Problem with NTP on asr9901 and sysadmin mode
Dear all,
I have a problem with NTP on asr9901. NTP configured and clock is sync. When I try to check time in admin mode, no association ID's returned. NTP can't be configured in admin mode.
Any help?
Thanks in advanced.
pieterh
looks  "by design" :the System Admin console clock will automatically synchronize with the XR console clock
Perform Clock Synchronization with NTP Server
There are independent system clocks for the XR console and the System Admin console. To ensure that these clocks do not deviate from true time, they need to be synchronized with the clock of a NTP server. In this task you will configure a NTP server for the XR console. After the XR console clock is synchronized, the System Admin console clock will automatically synchronize with the XR console clock.
NTP configured on router:
ntp
server X.X.X.X
source Loopback0
update-calendar
RP/0/RSP0/CPU0:#show ntp status
Thu Nov 21 12:12:53.099 CET
Clock is synchronized, stratum 3, reference is X.X.X.X
nominal freq is 1000000000.0000 Hz, actual freq is -43642704.8399 Hz, precision is 2**23
reference time is E180EF9B.F915C3AE (12:12:27.972 CET Thu Nov 21 2019)
clock offset is 1.263 msec, root delay is 7.402 msec
root dispersion is 28.50 msec, peer dispersion is 15.80 msec
loopfilter state is 'CTRL' (Normal Controlled Loop), drift is -0.0000239133 s/s
system poll interval is 1024, last update was 26 sec ago
authenticate is disabled
but there is on sync in sysadmin.
Best regards,
