Problem with: punt cause policer drop packet cause
Rajkob
Our hardware is SR4331-SEC/K9. We are experiencing following error in our log and it is reoccurring every 5 minutes:
Oct 29 05:55:51.539: %IOSXE-5-PLATFORM: R0/0: cpp_cp: QFP:0.0 Thread:001 TS:00000316323249890587 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet cause 60
Oct 29 06:00:48.155: %IOSXE-5-PLATFORM: R0/0: cpp_cp: QFP:0.0 Thread:001 TS:00000316619869100229 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet cause 60
Oct 29 06:05:58.273: %IOSXE-5-PLATFORM: R0/0: cpp_cp: QFP:0.0 Thread:001 TS:00000316929990127875 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet cause 60
Oct 29 06:11:00.509: %IOSXE-5-PLATFORM: R0/0: cpp_cp: QFP:0.0 Thread:001 TS:00000317232229458762 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet cause 60
When I run command:
show platform software punt-policer drop-only
I received the flowing response:
Per Punt-Cause Policer Configuration and Packet Counters
Punt Config Rate(pps) Conform Packets Dropped Packets Config Burst(pkts) Config Alert
Cause Description Normal High Normal High Normal High Normal High Normal High
60 IP subnet or broadcast packe 2000 1000 9935449 0 3452644 0 2000 1000 Off Off
Does anyone have any idea what is causing this?
Leo Laohoo
Raise a TAC Case. It could be CSCvq17377 or CSCvh79264.
