problem with remote login
hanwucisco
we use putty to login catalyst 3550. one of the switches recently doesnt let me login. this is the info given by putty:
"connection refused"
the user on the switch work fine.
what is the possible problem?
15 Replies 15
To my understanding still u r not able to login via ssh.
I had a similar problem ....
In my case it was login local at line 0 4 but just login for line 5 15 ...after changing to login local i was able to login via ssh in the created username.
Do u have aaa authentication...if not give login local at line 0 15..then try to login via ssh ....Prior u have to check u r local username
s.mahesvaran
