Problem with scheduled Reports in RME
simon.bell
In Reports > Report Generator, I'm trying to schedule a 24hour change audit report.
This report runs just fine if I run it immediately, however if I schedule it, it bombs out. Viewing the log file with Debug enabled for ChangeAudit, it looks like RME doesn't think the job owner username - ME - exists.
Job Configuration:
Change Audit > 24 Hour Report
All Devices
24 hours
Application: Archive Management
Category: CONFIG_CHANGE
Schedule: Anything other than Immediate FAIL
Configuration: LMS 3.0.1, Win2k3 Ent SP2, ACS integrated, Job Approval
enabled.
It looks like it only checks the local user database in CS even though we're ACS integrated...
Anyone else see this?
Joe Clarke
You are absolutely right. I found this problem a while ago, and filed CSCsm77700. I created a patch which you can get by contacting the TAC, and referencing this bug.
jclark, thanks for the heads up. I'll let my TAC engineer to let them know.
Could you contact me off line please?
simon
It looks like since the upgrade to LMS3.1 the bug has resurfaced with the same issue. I opened a new tac case but i expect the tac engineer to contact you.
sb
No, the bug is fixed in RME 4.2. I verified the code is correct.
