Problem with temperature Sensor Router 2801 and 2811 IOS 12.3(11)T11
RonaldJCM
I am monitoring devices with a software called zenoss, the Oid which is using to collect the temperature value from the router is
1.3.6.1.4.1.9.9.13.1.3.1.3. but when zenoss tried to collect temperature value from the cisco 2811
IOS 12.3(11)T11, it didnt recognize the oid.
what is the OID that I can use to collect cisco2800's temperature value?
Pulkit Nagpal
Moved the discussion to network management sub-community to help get quick response.
Pulkit Nagpal
Technical Support Community Manager- R&S
