Routing between two different MPLS networks
William Benson
I need to create a route between two different MPLS clouds hosted by different providers.  These clouds are not aware of each other so I need to direct the traffic myself.
Simple View:
Host1 - 10.52.124.100
Router1 - 10.52.124.3
MPLS CLOUD 1
Router2 - 10.52.120.56
Router3 - 10.52.120.3
MPLS CLOUD 2
Host2 - 172.31.19.11
I need to be able to ping from Host 1 (10.52.124.X) to Host 2 (172.31.19.11).  I know I need to NAT the traffic going out on Router3 to the 10.52.120.X network so the host2 on the other side of the MPLS cloud can pass it back.  But getting the traffic to Router3 to be passed into the MPLS cloud is the real hang up here.
I'm pretty sure I need to create some kind of forwarding address in the 10.52.120.X network to point to the 172.31.19.11 network.  I'm just not sure how to get the traffic to pass from one network to the other.  I have an ASA5510 on the 10.52.120.X network I can use as well.  I'm just not sure if there is something on the ASA I can take advantage of that the routers do not have.  Is there a way on the router to point (i.e.) 10.52.120.10 -> 172.31.19.11
Jon Marshall
Yes you can use NAT eg on router 3 -
int fa0/0 <-- this faces host2
ip nat inside
int fa0/1  <-- this faces router 2
ip nat outside
ip nat inside source static 172.31.19.11 10.52.120.10
Jon
