02-24-2019 04:32 PM
i have a couple of of these and are trying to put them to use at home but are having some trouble resetting and communicating with them. basically:
i use a crossover cable and putty to try and connect to the ap but i cant seem to get it into "config mode" if that makes sence.
i am running out of ideas and are not a pro in any way or form. i do though have quite good knowledge about it and some networking.
any help appreciated!
02-24-2019 09:57 PM
02-24-2019 11:49 PM
i am not familiar with capwap and have looked into mobility express but was unable to download the software as you have to be a cisco parter to get it of their site.
and i do not have the IOS. where do i get that?
02-26-2019 12:09 AM
i think i have found the required software: https://software.cisco.com/download/home/286256842/type/284180979/release/15.3.3-JI3
but again its not possible to download it? is this really the case that cant download anything from the site unless youre certified partner?
