Problem with user tracking Cisco Prime lms 4.2
When I use the User tracking utility, it dont find the usernames, I dont kwow if I have to use the tool UTlite33.exe un all end host or not, please helpme.
AFROJ AHMAD
Hi Andres,
Check this ::
Understanding UTLite
UTLite is a utility that allows you to collect user names from Primary Domain Controllers, Active Directory, and Novell servers.
To do this you need to install UTLite in the Windows Primary Domain  Controllers and in the Novell servers. You can also install UTLite in an  Active Directory server.
UTLite sends traps to LMS whenever a user logs in or logs out. UTLite  traps are processed by LMS at the rate of 150 traps per second, with a  default buffer size of 76800.
Follow the below link and it should help:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/user/guide/admin/appendixcli.html#wp1032284
Thanks-
Afroz
[Do rate the useful posts]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Andres,
Check this ::
Thanks-
Afroz
