problem
panarania3
Frequent Visitor
Frequent Visitor
hello everyone , I hope you are all well I connected kalilinux to eve_Ng but no commands work what is solution for that ?thanks for answering
I'm just trying to do network pen testing, when try to write commands it show me error for all command same...
So you looking to use - yersinia  (has this been installed ) - if not check suggested by @Seb Rupik  how to install
follow below video guide you better.
https://www.youtube.com/watch?v=EmpeIELC8bA
NOTE : this is Cisco community, not kali linux or pen testing forum
BB
6 Replies 6
balaji.bandi
what are you trying to do  here ? you looking to create account or change the user group ?
you need add use as below :
sudo adduser username
BB
not working bro
not working bro
i did not get what you looking to do ? adding user or installing package ? what is the task ?
BB
BB
Seb Rupik
Hi there,
The yersinia package is not part of the default Kali install, try the commands:
sudo apt-get update
sudo apt-get install yersinia
cheers,
Seb.
