Problems after LMS 2.6 Upgrade
1amoser
Since the upgrade, CiscoView is no longer visible in the CS>Soiftware Update>Device Updates Window! Application is still registred, but when trying to upgrade a dfm, error message "no registred with PSU" appears.
Thanks for any advises!
Joe Clarke
This is confusing. You say CiscoView is missing, but when you try to upgrade DFM you get an error? You cannot do anything with DFM from Device Update. Only Common Services, CiscoView, and RME are applicable there.
