Problems for connect database with lmddatafeed user
Luis Vicente
Community Member
I connected to cmfDb with cmfDBA user but  I can't reach with lmsdatafeed user.
I launched dbpasswd.pl dsn=cmf npwd=******** to change user password beacuse I was thinking that I was changing password for lmsdatafeed. Finally I can connect with db but only withcmfDBA.
Using SSQL Anywhere client I can see users but I don't  find lmsdatafeed on list.
I can't understand whats the matter, I don't know if there're a problem with db installation and I must launch dbaccess.pl install or how I can change password to user lmsdatafeed.
could it be that an anti-virus software is preventing the execution of dbaccess.pl?
7 Replies 7
AFROJ AHMAD
Enabling Access to Database
To enable the access to applications database, you must run the dbaccess.pl utility from the command line.
You must run:
NMSROOT/bin/perl NMSROOT/bin/dbaccess.pl {install|clean} [debug] on Solaris systems
NMSROOT\bin\perl NMSROOT\bin\dbaccess.pl {install|clean} [debug] — on Windows systems
where,
NMSROOT — Default CiscoWorks installation directory
install Command line parameter that cleans the existing views, creates new views and provides access to databases
clean Command line parameter that cleans the existing views
debug Prints the debug and warning messages on the screen
The default database view user name is lmsdatafeed. The CLI utility prompts you to enter the database view password.
You can enter password of length between 5 to 30 characters.
A few warning messages appear while running the utility with the debug option. These messages appear when the view definitions are not in the database.
For example, you may get the following warning messages while the utility enables access to Common Services database:
WARN: User ID 'lmsdatafeed' does not exist (DBD: execute failed).
WARN: Table 'Network_Devices' not found (DBD: execute failed).
WARN: Table 'Job_Details' not found (DBD: execute failed).
You can ignore these warning messages.
I hope this will help you !!!
for more information you can chekc the below link :
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/database_schema/guide/dbviews.html
Thanks--
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Martin Ermel
to reset the password of lmsdatafeed you can just re-run
NMSROOT\bin\perl NMSROOT\bin\dbaccess.pl install
you will be asked to set the password for user lmsdatafeed and the views will be dropped and regenerated. You wont loose any data in the database.
Details on the process can be found here:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/database_schema/guide/dbviews.html#wp69517
also keep in mind, that with dbaccess.pl you will not gain access to the databases (like cmd, ani, rmeng, ...) you just generate certain predefined views and the user "lmsdatafeed" who has READ access only to these views. The views themselves provide you structured data from different tables of the different databases - and the schema of these views is published - so you can make use of this data.
Direct database access is still not supported by Cisco.
With dbpasswd.pl you do NOT change the password of the user "lmsdatafeed" but of the internally used user (as you mentioned, for cmf it is cmfDBA)
We launch dbaccess.pl install debug yesterday. There aren't response yet.
We must stop any service? Whats matter?
do I understand correctly, that you executed dbaccess.pl and you did not get a response back from the script ?
No services needs to be stopped.
can you please open another DOS box and provide the output of "pdshow" and "pdshow -brief"
Exactly, dbaccess.pl doesn't work and there aren't response.
We executed "pdshow -brief" and this is the response:
C:\Program Files (x86)\CSCOpx\bin>pdshow -brief
  Process               State                                     Pid
  Tomcat                Program started - No mgt msgs received    2380
  TomcatMonitor         Running normally                          2652
  Apache                Program started - No mgt msgs received    2900
  RMEDbEngine           Program started - No mgt msgs received    4700
  Proxy                 Program started - No mgt msgs received    4808
  ProcSysBus            Program started - No mgt msgs received    4816
  OpsxmlDbEngine        Program started - No mgt msgs received    4860
  OpsXMLRuntime         Program started - No mgt msgs received    4956
  CWAPublisher          Administrator has shut down this server   0
  NameServer            Program started - No mgt msgs received    5028
  NameServiceMonitor    Running normally                          5432
  EDS                   Running normally                          5676
  LicenseServer         Program started - No mgt msgs received    12
  IpmDbEngine           Program started - No mgt msgs received    5964
  INVDbEngine           Program started - No mgt msgs received    6288
  FHPurgeTask           Never started                             0
  FHDbEngine            Program started - No mgt msgs received    6392
  ESS                   Program started - No mgt msgs received    6496
  EssMonitor            Running normally                          6592
  EventFramework        Program started - No mgt msgs received    6808
  PMServer              Running normally                          6816
  SyslogCollector       Program started - No mgt msgs received    6248
  EPMDbEngine           Program started - No mgt msgs received    6256
  EPMServer             Running normally                          7328
  FHServer              Running normally                          7832
  diskWatcher           Running normally                          7840
  DFMMultiProcLogger    Program started - No mgt msgs received    7848
  DFMLogServer          Program started - No mgt msgs received    7856
  DFMCTMStartup         Administrator has shut down this server   0
  DfmBroker             Program started - No mgt msgs received    7876
  DfmServer             Running normally                          7984
  DfmServer1            Running normally                          7992
  DCRDevicePoll         Program started - No mgt msgs received    8572
  CSSCPServer           Program started - No mgt msgs received    8000
  CSRegistryServer      Running normally                          8008
  CSDiscovery           Never started                             0
  CmfDbEngine           Program started - No mgt msgs received    8124
  CmfDbMonitor          Running normally                          8368
  DCRServer             Running normally                          8436
  CMFOGSServer          Program started - No mgt msgs received    8624
  CampusOGSServer       Program started - No mgt msgs received    9212
  EssentialsDM          Running normally                          8256
  ConfigMgmtServer      Program started - No mgt msgs received    8564
  ICServer              Running normally                          8248
  RMEOGSServer          Program started - No mgt msgs received    8616
  PMCOGSServer          Program started - No mgt msgs received    9400
  TISServer             Program started - No mgt msgs received    9408
  DFMOGSServer          Program started - No mgt msgs received    9772
  InventoryCollector    Running normally                          9252
  Interactor            Program started - No mgt msgs received    9260
  InventoryCollector1   Program started - No mgt msgs received    8700
  Interactor1           Program started - No mgt msgs received    10496
  NOSServer             Running normally                          10504
  PTMServer             Running normally                          10512
  EDS-GCF               Running normally                          10520
  jrm                   Running normally                          10528
  CTMJrmServer          Running normally                          11448
  ChangeAudit           Program started - No mgt msgs received    11292
  SyslogAnalyzer        Program started - No mgt msgs received    12180
  DataPurge             Administrator has shut down this server   0
  IPMProcess            Program started - No mgt msgs received    12192
  IPMOGSServer          Program started - No mgt msgs received    9364
  1806                  Program started - No mgt msgs received    16184
  ANIDbEngine           Program started - No mgt msgs received    10120
  ANIServer             Running with busy flag set                11400
  UTMajorAcquisition    Transient terminated                      0
  MACUHIC               Running normally                          12548
  UTLITE                Running normally                          12556
  UTManager             Running normally                          12564
  VNMServer             Program started - No mgt msgs received    12572
  WlseUHIC              Running normally                          12580
  AdapterServer1        Program started - No mgt msgs received    12588
  AdapterServer         Program started - No mgt msgs received    12596
There aren't antivirus installed.
[Edited]
Finally Reboot the server and the command worked : O
Thanks you very much!!
Best regards.
