04-09-2009 09:22 PM
I had changed an interface state to false, but after several hours it has
been changed back to true. I have find out the issue under DFM 3.1.2 and I have upgrade to 3.1.3, but patch is not fixing the problem.
04-09-2009 10:07 PM
When you changed the state, did you apply the changed to the DFM server (i.e. DFM > Configuration > Polling and Thresholds > Apply Changes)? Did you reboot the server after doing this? Did a DFM rediscovery run for this device during this time?
04-09-2009 11:00 PM
Yes, of course I have applied changes. No I have not reboot server after this. No, rediscovery was not run after updating interface state.
04-10-2009 07:40 AM
I am also running into this, does any one know of a fix?
04-10-2009 08:53 AM
About how long do you have to wait before the interface status reverts back to true? What interface types did you unmanage? I am trying to recreate this problem locally.
04-10-2009 08:59 AM
My LMS was a clean install, and I also upgraded it to the newest updates.
I have tried this is Ethernet Interfaces, Tunnels, a NAM external interface.
Im going to try and time the issue, I have wiped out my databases and I am rediscovering...
04-10-2009 02:28 PM
I cannot reproduce. I unmanaged two interfaces (an ATM interface and a Dialer interface) on a 3745 using the Detailed Device View. I applied my changes. After about six hours, both interfaces are still unmanaged.
04-12-2009 05:43 AM
I have this issue with Serial, Ethernet and Virtual interfaces. I have this interfaces in managed state on the next day.
04-12-2009 10:49 AM
I still cannot reproduce even after two days. If you notice this on the next day, that implies that a rediscovery does run (since rediscoveries run at 0200 every day by default). Try forcing a rediscovery of the device after setting the interfaces to their desired states. Go to DFM > Device Management > Rediscover/Delete to do the rediscovery.
04-12-2009 11:45 AM
I was able to reproduce after running a rediscovery on the device in question. I found the problem, and created a patch against DFM 3.1.3. If you contact the TAC, and have your engineer contact me directly, I can provide the patch.
04-12-2009 09:31 PM
Yes, today I have discovered same behaviour. I have asked the case engineer Christine Oh to contact you.
04-13-2009 10:59 PM
I filed CSCsz08953 to track this issue.
