Protected Ports mib
gula
we are working with switch - catalyst 2960-x ,
how can I configure Protected Ports ( switchport protected ) via snmp ?
what is the mib?
marce1000
  You must have an snmp-write enabled and known snmp community (string); then you could use the CISCO-COPY-CONFIG-MIB to copy templates from an external server to designated ports (google allso on' CISCO-COPY-CONFIG-MIB examples')
M.
marce1000
M.
gula
I am looking for mib and oid for   port protected
I found only way to configure it via command line
Switch# configure terminal
Switch(config)# interface gigabitethernet0/1
Switch(config-if)# switchport protected
Switch(config-if)# end
I need do the same , but via snmp
