Protocol rate limiting
belliott12
Community Member
How can I limit the bandwidth usage of a IP protocol
Example : I want to only allow 25% bandwidth of an ATM
PVC T1 ( Email or SMPT )
Bill Elliott
amritpatek
Level 11
Level 11
Yes. It can be done with help of Commited Access Rate feature of ATM Switches.
http://www.cisco.com/en/US/products/hw/switches/ps718/products_configuration_guide_chapter09186a008007cf09.html
tabbott
You may want to look to establish a QoS congestion policy to the outbound interface such that SMTP is in a class that can only get 25% of the bandwidth under congestion. Another way would be to use the police command on the interface. It may be available on ATM but it definetly is on the ethernet which may be the connection to your LAN.
paupot
Level 2
Level 2
Create an acl permitting the SMTP traffic
then, on interface level
traffic-shape group
It will shape all traffic exceeding the max-size.
hth
paul
