Purge archive Mgmt Problem
angelapreta
On CW 2.5 I have configured the purge of archive Mgmt. It does not work. After 15h the job finished with fail status. I have incresed the archive Mgmt fetch settings suggestet in the error status from the each device. Can someone help.
Joe Clarke
Exactly which version of RME do you have? Exactly what is failing? Is it the config purge job, or is it a configuration sync job (i.e. a job that is fetching the configurations from your devices)?
RME version: 4.0.4
it is the config purge job
The job does not purge any conf-files. The policy does retain 5 versions
For this, you should enable ArchiveMgmt Service debugging under RME > Admin > System Preferences > Loglevel Settings. Then wait for another job to run, and look for errors in dcmaservice.log. Note: configurations with associated ChangeAudit records will not be purged, so make sure you are purging those as well.
debugging for ArchiveMgmt Service is active
I found no information or errors in dcmaservice.log for this purge job. I changed the purge policy with same result -> Failed.
There is a ChangeAudit job running
