Q: CAN you repeatedly SSH from within a TCL script to, for example, a radio . . .
tproeber
. .. to get the current Line Rate to then write that speed to the Bandwidth statement for an Interface to make routine protocols more accurate over radio links with varying modulations?
My Googling says tells me that you can log in but any commands you issue will hang.  Can you SSH and retrieve command results from remote hosts in Cisco TCL?
Thanks!
Tim
18 Replies 18
*Nov 21 10:23:59 UTC: %HA_EM-6-LOG: Int-Desc : DEBUG(cli_lib) : : OUT : 2901_Ship_4#
*Nov 21 10:23:59 UTC: %HA_EM-6-LOG: Int-Desc : DEBUG(cli_lib) : : IN  : 2901_Ship_4#ssh -l cobra 192.168.101.1
*Nov 21 10:24:00 UTC: %HA_EM-6-LOG: Int-Desc : DEBUG(cli_lib) : : OUT : Password:
*Nov 21 10:24:00 UTC: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: 9
*Nov 21 10:24:00 UTC: %HA_EM-3-FMPD_ERROR: Error executing applet Int-Desc statement 050
*Nov 21 10:24:00 UTC: %HA_EM-6-LOG: Int-Desc : DEBUG(cli_lib) : : CTL : cli_close called.
*Nov 21 10:24:00 UTC: tty is now going through its death sequence
2901_Ship_4#
Statement 50 is the password -- it's the correct password -- I can manually do the steps.
Tim
Found it -- I had to escape the $ sign in the password.
Progress!
Tim
I can SSH to the radio!
Now I need to extract the TX ands RX rates and range -- is this how I would do it?
event manager applet Radio-Reader
event timer watchdog time 10
action 010 cli command "enable"
action 020 cli command "ssh -l ubnt 192.168.2.11" pattern "assword:"
action 050 cli command "fly2the*" pattern "#"
action 060 cli command "mca-status" pattern "#"
action 070 regexp "wlanTxRate=[0-9]{1,3}" "$_cli_result"
action 080 set 900Mhz-TX "$_regexp_result"
action 090 regexp "wlanRxRate=[0-9]{1,3}" "$_cli_result"
action 100 set 900Mhz-RX "$_regexp_result"
action 110 regexp "distance=[0-9]{1,3}" "$_cli_result"
action 120 set 900Mhz-Distance "$_regexp_result"
***** This is the output of the "mca-status" command:
XM.v5.5.6# mca-status
deviceName=2.4_AP.11,deviceId=DC:9F:DB:6A:A2:17,firmwareVersion=XM.ar7240.v5.5.6.17762.130528.1755,platform=Rocket M2,deviceIp=192.168.2.11
apMac=DC:9F:DB:6A:A2:17
wlanOpmode=ap
wlanConnections=3
wlanUptime=1142923
essid=2400
freq=2429
signal=-41
noise=-89
ccq=991
uptime=1142923
loadavg=0
memTotal=62012
memFree=43204
memBuffers=2340
ackTimeout=24
distance=0
lanIpAddress=0.0.0.0
wlanIpAddress=0.0.0.0
wlanTxRate=260.0
wlanRxRate=174.0
wlanTxLatency=1
wlanPolling=1
wlanPollingQuality=79
wlanPollingCapacity=62
lanRxBytes=414272179
lanRxPackets=477266935
lanRxErrors=0
lanTxBytes=1544971571
lanTxPackets=53035448
lanTxErrors=0
lanPlugged=1
lanSpeed=100Mbps-Full
wlanRxBytes=2040744381
wlanRxPackets=59880613
wlanRxErrors=1
wlanTxBytes=4012972456
wlanTxPackets=479018827
wlanTxErrors=0
wlanRxErrNwid=1147816
wlanRxErrCrypt=0
wlanRxErrFrag=0
wlanRxErrRetries=0
wlanRxErrBmiss=0
wlanRxErrOther=0
latitude=0.000000
longitude=0.000000
cfgCrc=1dee1a80
XM.v5.5.6#
Don't over-think it.  Use as simple expression as you can:
regexp "wlanTxRate=([0-9\.]+)" $_cli_result match txrate
puts "TxRate is $txrate"
==> TxRate is 260.0
