[Q] Trigger an event for calls passing through a CUBE
pethomas
Hi Guys
Are there any events I could catch to trigger a script for new calls as they pass through a CUBE?
I'm wanting to set up an alert based on a certain number been dialed.
Ta
Peter
Joe Clarke
Not directly, but Tcl IVR can help here.  You can use IVR to generate a syslog message that EEM can process.  I'm not sure if this is applicable to CUBE, though (it works with CME).  Here's one such example implementation:
https://supportforums.cisco.com/docs/DOC-19345
Thanks Joe
I''ll give that a go and report back.
cheers
Peter
