QoS on a Dialer interface (ADSL Connection)
peter.rowe
I have been trying to implement a simple QoS policy for outbound traffic on a dialer interface on 1721 and 837/877
I cannot get the policy to match any traffic (see below) Can someone confirm if this is indeed possible - not actaly queueing appears to happen whatsoever. An identical config on an ethernet interface works A OK.
Thanks!
peter#sh policy-map interface d1
Dialer1
Service-policy output: VOICE-POLICY
Class-map: voice-traffic (match-all)
463726 packets, 98224103 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: access-group name voice_traffic
Queueing
Strict Priority
Output Queue: Conversation 72
Bandwidth 50 (%)
Bandwidth 128 (kbps) Burst 3200 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
QoS Set
dscp ef
Packets marked 416124
Class-map: voice-signaling (match-all)
42905 packets, 3491605 bytes
Match: access-group name voice_control
Queueing
Output Queue: Conversation 73
Bandwidth 8 (kbps) Max Threshold 64 (packets)
(depth/total drops/no-buffer drops) 0/0/0
Class-map: citrix (match-all)
571327 packets, 47176156 bytes
Match: access-group name citrix_traffic
Queueing
Output Queue: Conversation 74
Bandwidth 24 (kbps) Max Threshold 64 (packets)
Class-map: telnet (match-all)
218 packets, 27700 bytes
Match: access-group name telnet_traffic
Class-map: class-default (match-any)
7232707 packets, 4460899597 bytes
30 second offered rate 5000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 64
(total queued/total drops/no-buffer drops) 0/0/0
spremkumar
Level 9
Level 9
Can you post out the config taken out from both 172 and 837 routers ??
regds
Sure, config for 1721 is attached (the 837 config is pretty much identical) I have removed the VPN stuff as it;s not really relevant, no queueing ever happens, although the traffic is being recognised.
