QPM Install Problem
Yousofzai
Community Member
Dear community,
I installed qpm 4.1 on a new server.
I can start common services, but I can not start QPM. I get the error
The QPM application is not fully started. Please close the window and try launching after few minutes
I checked the processes and I mentioned that the the process
QpmAppServer
does not start.
I tried to start this process manuelly, but unfortunatly without success.
I thank you in advance for your suggestions.
Sincerly.
Yama
Yousofzai
Community Member
Changing the following entry in the registry will solve the problem:
1) Stop LMS:
# net stop crmdmgtd
2) Go to RUN and type regedit to open the Registry editor
3) Go to
HKEY_LOCAL_MACHINE\SOFTWARE\Cisco\ResourceManager\CurrentVersion\Daemons\QPMAppserver
If it is a 64Bit-Server, you find the entry under
HKEY_LOCAL_MACHINE\SOFTWARE\ Wow6432Node\Cisco\ResourceManager\CurrentVersion\Daemons\QPMAppserver
4) Right click on the RunAsSystem, select Modify on the context menu and change the value to "1".
5) Start LMS and the problem should be resolved.
