questions about LMS 3
tverhoeven
Just installed LMS 3 from scratch and then imported the devices from 2.6. Things went fairly smoothly with a couple of exceptions.
1. Are the 3750 NME supported in the version
2. I am seeing the following:
Down Processes DFMCTMStartup, DataPurge
Log Space Usage CVDeviceSelector.log
thanks
tony
Joe Clarke
I'm betting that the answer is no, but I will need to get the sysObjectID of the device to confirm.
These processes are typically down. Administrator shutdown is a healthy state for them.
akemp
Level 5
Level 5
1. lots, not all and none fully for RME. The other apps work well on them though. You will get some information but not everything. The 48 port (last digit in the IOD 666) is not (I have about 270 of them) while the 24 port is.
2. Data purge is a periodic job .. if its running all the time you've got problems. the CLI command PDshow will let you know the real status.
