Re: Cat 3750 Stack Management
waldobriggs
I am building a few 3750 stacks with three or more units, I want to be able to poll/monitor each  individual switch in the stack but as it only has 1 ip associated with  the stack, how can I do this?   I am blind to a switch  going down in the middle of the stack.  I saw this in a four-year-old forum, but I say no specific resolution.
Joe Clarke
All stack management happens through the commander.  The stack looks like a huge switch.  If you want to monitor a specific switch's interfaces you can.  They will be numbered as *EthernetX/0/Y, where X is the stack member number and Y is the interface number.  CPU utilization can only be monitored on the active stack master, though.  Inventory can be obtained from each stack member using ENTITY-MIB.  Environmental data can be obtained for each switch using the CISCO-ENVMON-MIB.
