Read crashinfo and crashinf_ext
ksbolton1
Hello. I've recently pulled some crashinfo files from a switch that encountered a failure, where all startup and running config was lost. I'd like to know what the procedure is for analyzing the crashinfo files and hopefully find the source of error.
Mark Malone
So crash files are only for TAC , that's why there are no released documents specifying how to read them , they have their own systems that are able to analyse the code that's provided in them
saying that if you open them up sometimes I have found the fault in them but there difficult to read  , but most of the traceback outputs are not public so its very difficult to find the reason for them without TAC , you could run your show tech through the cli analyser and see if it pulls a bug for you but even tat I don't think can read a crash file and that's the most powerful tool available to public
Information to Collect if You Open a TAC Service Request
If you still need assistance after following the troubleshooting steps above, and want to open a service request with the Cisco TAC, be sure to include the following information for troubleshooting a router crash:
  • Troubleshooting performed before opening the service request.
  • show technical-support output (if possible, in enable mode).
  • show log output or console captures, if available.
  • crashinfo file (if present, and not already included in the show technical-support output).
  • show region output (if not already included in the show technical-support output).
Please attach the collected data to your service request in non-zipped, plain text format (.txt). You can attach information to your service request by uploading it using the TAC Service Request tool (registered customers only) . If you cannot access the Service Request tool, you can attach the relevant information to your service request by sending it to attach@cisco.com with your case number in the subject line of your message.
Note: Please do not manually reload or power-cycle the router before collecting the above information unless required to troubleshoot a router crash, as this can cause important information to be lost that is needed for determining the root cause of the problem.
Mark Malone
I see, thank you for this information. It explains a lot.
