Receive Power Sensor
hello everyone,
my name is william, and am a newbie well i have been using PRTG to monitor my network and i have noticed this error
-1.80 dBm (Gi1/0/25 Receive Power Sensor) is above the warning limit of -3.10 dBm in Gi1/0/25 Receive Power Sensor — -2.10 dBm (Gi1/0/26 Receive Power Sensor) is above the warning limit of -7.10 dBm in Gi1/0/26 Receive Power Sensor
can anyone give me insights on Rx power sensors and Tx power sensors? and how they can impact the perfomance of my network? and what should i do to resolve this error? thanks
Mark Elsen
 - These could be false alarms check the logs for the involved switches; look for similar messages , if any. Compare to direct measurements for db signal strength with info found in example links such as  :
    https://community.fs.com/blog/check-sfp-module-optical-signal-strength.html
    https://www.cisco.com/c/en/us/support/docs/optical/synchronous-optical-network-sonet/16150-measure.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
