03-22-2010 11:33 AM
Hi all,
We have been experiencing issues with our backup Internet Circuit due to issues with BGP.
Our local router is being monitored and managed by DFM, is there any way to get alerts for BGP events?
I.E. Possibly configuring syslog collector to filter logs based on BGP ADJChange and send email alerts.
Solved! Go to Solution.
03-22-2010 01:42 PM
Sure. You can configure an RME automated action to send you emails when you get such syslog messages. Your AA config will look like:
Facility : BGP
Sub-facility : *
Severity : 5
Mnemonic : ADJCHANGE
Description : *
The action type will be email. Just make sure the devices are configured to send syslog messages to the RME server at the proper facility (local7 by default).
03-22-2010 01:42 PM
Facility : BGP
Sub-facility : *
Severity : 5
Description : *
03-22-2010 01:59 PM
Sounds good.....I read this in the documentation.
Always good to double-check before I implement this......I'm only going to be configuring this for about 5 or 6 routers so the directory
shouldn't grow to much if I configure this correctly.
