Recommend Performance monitor for interface
urvininocente
I am configuring my network monitoring application to monitor my Cisco Routers and I am looking for recommended (best practice) thresh hold values for following the interface parameters (Ethernet interface):
Bandwidth Utilization (%)
Error rate (%)
Package discarded (%)
Any help, documents or advice  would be appreciated
Screech
Michel Hegeraat
Level 7
Level 7
Here is my 2 cents
Don't think there is a one size fits all
Trunks and other connection between network devices
Bandwidth  Utilization 60% on full duplex 40% on half
Error rate  0
Package discarded 0
These interface should be absolutely clean, and you beter check Transmit load and Receive Load rather then Utilization
Userports
Error rate  5
Package discarded 5
Server ports
Error rate  1
Package discarded 1
I would say it is pointless to poll and monitor all ports for bandwith utilisation all the time.
Using rmon or something else to set (a couple of) thresholds and monitor that  is a much better idea
Not sure about a tool that could used for that however.
Cheers
Michel
Michel Hegeraat
Level 7
Level 7
Here is my 2 cents
Error rate  0
Package discarded 0
Userports
Error rate  5
Package discarded 5
Server ports
Error rate  1
Package discarded 1
Cheers
Michel
