redirect show tech to tftp on 3750
burlingtoniowa
Hi Cisco Community,
On my 2960, 3550, and 2801 equipment which all have IOS 12.2 or 12.3 I am able to obtain things like "show tech" and save it on a tftp server in this manner:
ch3550#show tech | redirect tftp://192.168.18.18/techsupport.txt
This is because the | pipe has a bunch of options it refers to as output modifiers.
ch3550#show tech | ?
  append    Append redirected output to URL (URLs supporting append operation only)
  begin     Begin with the line that matches
  count     Count number of lines which match regexp
  exclude   Exclude lines that match
  format    Format the output using the specified spec file
  include   Include lines that match
  redirect  Redirect output to URL
  section   Filter a section of output
  tee       Copy output to URL
HOWEVER, on my 3750, I am not able to do this. The list of output modifiers has changed, and "redirect" is not available. Consider the following:
ch3750#show tech | redirect tftp://192.168.18.18/techsupport2.txt
% Invalid input detected at '^' marker.
ch3750#show tech | ?
The 3750 unit I am working with is WS-C3750G-12S with IOS version 12.2(25)SEB2
Now, I know I can capture the show tech output via other means such as in the buffer of Putty.exe...
but finding this out has become a matter of principle now!
thanks!
mtoal
Leo Laohoo
That's because your 3750 is running a very old IOS.
Leo Laohoo
My apologies for not replying sooner.
Upgrading did resolve the issue.
thanks!
Thanks for the ratings.
