Reg:network management tool
vasuramnet
Level 3
Level 3
Dear sir,
One of my customer is having reliance 2mps link through this they r sending the bandwidth to his remote branches through 64kbps leased lines.Now the problem is reliance people is saying my customer is using compleet 2mbps but if i down load some file my customer is not able to get that 2mb speed .So band width utilisation is more.How can i found this.For this any tool is there to see how much bandwidth is going to each pc and remote branches also.Plz help me how can i resolve this issue.
waiting for reply.
srini
9246571397
amolrajgure
Community Member
I guess, you can try with Netflow Analyser...
http://manageengine.adventnet.com/products/netflow/index.html
Iperf is your solution. Free and easy to use
