regular syslog message during condition
leogal777
Frequent Visitor
Frequent Visitor
Hello gents,
I would like to create EEM applet, that will monitor a link, when that link goes down it will send a syslog message every minute until the moment the link comes back up.
I have this functioning
ip sla 11
icmp-echo 172.25.5.2
threshold 50
timeout 500
frequency 1
ip sla schedule 11 life forever start-time now
ip sla reaction-configuration 11 react timeout threshold-type immediate
ip sla enable reaction-alerts
event manager applet sla1
event ipsla operation-id 1 reaction-type timeout
action 100 syslog msg "Bla bla bla $_ipsla_react_type $_ipsla_condition"
But I am struggling with that timing and regular messages during indefinite interval, maxrun etc.
Can anyone please suggest how to do this?
Thank you
Leo
Joe Clarke
The event you're using is edge-triggered.  If you really want to generate a syslog every minute (I honestly wouldn't recommend this as operators might learn to ignore the "noise"), then use a timer ED:
 event timer watchdog time 60
 action 1.0 cli command "enable"
 action 2.0 cli command "show ip sla stat 1"
 action 3.0 regexp "Timeout" "$_cli_result"
 action 4.0 if $_regexp_result eq 1
 action 5.0 syslog msg "..."
 action 6.0 end
You may want to extract more from the CLI output to populate your syslog.
Joe Clarke
 action 6.0 end
Thank you Joe
🙂 I took it from the wrong side.
