Reload requested by Environmental monitor. Reload Reason: Forced Reload
daniel.skilling
Cisco IOS Software, 901 Software (ASR901-UNIVERSALK9-M), Version 15.4(3)S, RELEASE SOFTWARE (fc3)
####Syslogging shows 52 reloads in the last 3 months and says Reload requested by Environmental monitor. Reload Reason: Forced Reload
BPS27.JUD#sh version
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sun 27-Jul-14 12:26 by prod_rel_team
ROM: System Bootstrap, Version 15.4(3r)S3, RELEASE SOFTWARE (fc1)
BPS27.JUD uptime is 1 day, 6 hours, 21 minutes
System restarted at 09:52:18 NZST Sun Aug 7 2016
System image file is "flash:asr901-universalk9-mz.154-3.S.bin"
Last reload type: Normal Reload
Last reload reason: Forced Reload
#### Above says...... Last reload reason: Forced Reload... I believe this is a bug due to the constant fan bumping alarms causing the below issue that says WARNING: Event Table Overflowed !!!
BPS27.JUD#sh environment
 Power Supply Status:
   12AV  Supply: +12.010 V Normal
   1.5V  Supply: +1.510 V Normal
   12BV  Supply: +11.980 V Normal
   2.5V  Supply: +2.510 V Normal
   1.05V Supply: +1.090 V Normal
   1.2V  Supply: +1.200 V Normal
   1.8V  Supply: +1.800 V Normal
 Fan Status:
 Fan 1 Operation: Normal, is running at 13   percent speed
 Fan 2 Operation: Failed
 Alert settings:
   Board temperature, temperature warning: Enabled
   Threshold: 83 (high) -40 (low) DegC
 Board Temperature: Normal
   Board temperature,  temperature = 30 (C), Normal
 Environmental monitor experienced the following events:
   SeqNum           Event              State             Time
       4  :  Fan                   : "2 fail  " at 11:55:35 NZST Sun Aug 7 2016.
       5  :  Fan                   : "2 fail  " at 12:55:34 NZST Sun Aug 7 2016.
       6  :  Fan                   : "2 fail  " at 13:55:34 NZST Sun Aug 7 2016.
       7  :  Fan                   : "2 fail  " at 14:55:34 NZST Sun Aug 7 2016.
       8  :  Fan                   : "2 fail  " at 15:55:34 NZST Sun Aug 7 2016.
       9  :  Fan                   : "2 fail  " at 16:55:34 NZST Sun Aug 7 2016.
      10  :  Fan                   : "2 fail  " at 17:55:34 NZST Sun Aug 7 2016.
      11  :  Fan                   : "2 fail  " at 18:55:34 NZST Sun Aug 7 2016.
      12  :  Fan                   : "2 fail  " at 19:55:34 NZST Sun Aug 7 2016.
      13  :  Fan                   : "2 fail  " at 20:55:34 NZST Sun Aug 7 2016.
      14  :  Fan                   : "2 fail  " at 21:55:34 NZST Sun Aug 7 2016.
      15  :  Fan                   : "2 fail  " at 22:55:34 NZST Sun Aug 7 2016.
      16  :  Fan                   : "2 fail  " at 23:55:34 NZST Sun Aug 7 2016.
      17  :  Fan                   : "2 fail  " at 00:55:34 NZST Mon Aug 8 2016.
      18  :  Fan                   : "2 fail  " at 01:55:34 NZST Mon Aug 8 2016.
      19  :  Fan                   : "2 fail  " at 02:55:34 NZST Mon Aug 8 2016.
      20  :  Fan                   : "2 fail  " at 03:55:34 NZST Mon Aug 8 2016.
      21  :  Fan                   : "2 fail  " at 04:55:34 NZST Mon Aug 8 2016.
      22  :  Fan                   : "2 fail  " at 05:55:34 NZST Mon Aug 8 2016.
      23  :  Fan                   : "2 fail  " at 06:55:34 NZST Mon Aug 8 2016.
      24  :  Fan                   : "2 fail  " at 07:55:34 NZST Mon Aug 8 2016.
      25  :  Fan                   : "2 fail  " at 08:55:34 NZST Mon Aug 8 2016.
      26  :  Fan                   : "2 fail  " at 09:55:34 NZST Mon Aug 8 2016.
      27  :  Fan                   : "2 fail  " at 10:55:34 NZST Mon Aug 8 2016.
      28  :  Fan                   : "2 fail  " at 11:55:34 NZST Mon Aug 8 2016.
      29  :  Fan                   : "2 fail  " at 12:55:34 NZST Mon Aug 8 2016.
      30  :  Fan                   : "2 fail  " at 13:55:34 NZST Mon Aug 8 2016.
      31  :  Fan                   : "2 fail  " at 14:55:34 NZST Mon Aug 8 2016.
      32  :  Fan                   : "2 fail  " at 15:55:34 NZST Mon Aug 8 2016.
BPS27.JUD#
marce1000
 - Looks like you have a fan-board failure; have your hardware repaired.
M.
- Yes thanks, I realise that but it shouldn't cause ASR901 to reload. The temperature is normal and the other fan is working fine and the power supply status is fine.
Fan fails shouldn't cause the ASR901 to self reload.
