Reloading router 819 series then cellular can't connect.
pancelot123
I have lots of 819 routers with the same problem. When there is a problem with primary GSM operator router reconnect to secondary GSM operator. Sometimes something will happen and  it doesn't connect  to any and hang.
I try to made reload event with sla and track but track delay is limited to 180 sec. and sometimes router has no enough time to connect to Internet after start and made cycle reboot.
Heave you any idea what I could do?
Joe Clarke
