Removing location configuration
foad
Would anyone know how to remove the location configuration "location civic-location-id none" from an interface?
interface GigabitEthernet1/0/16
I have tried "no location civic-location-id none" and defaulted the interface but the configs stays on the interface..
balaji.bandi
what is the device model and what IOS code it running.
can you post after default the interface
show run inter gi 1/0/16 ?
BB
babelk
After a default interface gi 1/0/44
Building configuration...
Current configuration : 72 bytes
interface GigabitEthernet1/0/44
end
proc
I've got this problem too which causes our phones not to work in the ports where this is configured.
If i go into the config mode of the port and run a
The config is still on the port. I've tried creating a location id of 1, associating that to the port and then running the command but it reverts back to
Where I want to get rid of that bit of config altogether from the interface.
Does anyone know how?
