Gateway to Gateway Tunnels won't connect after many years of using
bill p
I have two VPN Routers: RV320 & LRT214
I have been happily using the Gateway to Gateway VPN tunnel for several years without any problems.
But seemingly overnight a problem occurred. The Gateway to Gateway tunnel will not connect!
It is one particular physical location to another. (Other locations can Gateway to Gateway with each other.)
I can connect to the RV320 using Client to Gateway Easy VPN and I can connect to the LRT214 using Client to Gateway Open VPN
I have updated the restarted both, updated the firmware, etc. Any other ideas?
Thank you!
Mark Elsen
        - Check logs on both devices (and enable debugging levels , if applicable) ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
bill p
This is what I see in the RV320 logs
 [Tunnel Authorize Fail] DES_CBC is not enabled for this connection. Attribute OAKLEY_HASH_ALGORITHM
This from the LRT214 logs:
Connection Refused - Policy violation
             >....This from the LRT214 logs Connection Refused - Policy violation
           You should take that as a hint , perhaps someone made some changes on it ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
