Repoting
jefvaneijk
Level 2
Level 2
Is there a solution to get a msg or something when a arhive update failed?
Are there script's to automate some reporting, some ar standard in CW but there not so usefull.
umedryk
Level 11
Level 11
There are no ready scirpts available which you can change some parameters to use it. you need to write your own script for this.
