DFM
cminard
Level 3
Level 3
When accessing DFM from the network, getting the error message : cannot attach to domain.
when accessing from the CiscoWorks server, I have no problem ...
The commands "brcontrol", "pdshow Dfmserver" and "pdshow DfmBroker" show that DFM is running normally.
I have no proxy and no firewall between the network client and the ciscoworks server.
Any idea please ?
steve.busby
Level 10
Level 10
Two things to look at on your client machine.
Do you have a pop-up blocker and are you allowing pop-ups from CW2K?
Your Java applets may be corrupt. You can usually uninstall java and remove any leftover java folders/files from your Documents and Settings folder. Then hit your CW2K box again to let it reinstall java.
Steve
