Reserving Bandwidth for certain IP range
kiran_8095
I have two 6509 switches located in two different offices(connected through 40Mbps pipe). And i have to reserve bandwidth of 2Mbps for certain IP range between these offices. how do i accomplish this.
Jon Marshall
It does depend on your supervisor and PFC level but if you have a PFC3 card then the 6500 provides something called User Based Rate Limiting. See attached link for more details
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper0900aecd803e5017.html
Jon
hi ,
thanks for the information. the actual requirement is to reserve 2mbps bandwidth for the data between Servers located in the locations. can i achieve this using user based rate limiting.
thanks
k
User based rate limiting is a bit of a misleading term actually as it is based on source and/or destination IP address so yes this should fit your requirements.
Jon
