Not able to take proper inventory from cisco works
cisco__kaushik
Level 4
Level 4
Hi,i am not able to collect the serial numbers of 6500 line cards or the serial number of the secondary sup engine from cisco works version 2.6 .Pl advice
m.sir
Level 7
Level 7
Device Troubleshooting tab --> DEVICE CENTER ---> Device selector Enter IP of 6500 and click go ---> than reports and Detailed Device report
You should get list of modules and its serial numbers
M.
Hope that helps rate if it does
