Reset ACS 3.3 configuration and databases
pkh
I have an existing installation of ACS 3.3. I would like to clear all configuration and databases so that I can "start from scratch." This way, I can re-configure ACS as if it was a brand-new installation. Please advise. Thanks.
vkapoor5
Level 5
Level 5
Clear NVRAM entries and reload the router.Once the NVRAM entries are cleared startup config would be erased and then the reload would be like a new configuration.
I need to reset the configuration and the databases on ACS 3.3, not the router itself. Thank you.
