reset password of ME3600x-24fs-M
chpmotry
hi guys.
i have a laptop ASUS VivoBook 15 R521JA and the ME3600x-24fs-M switch that i dont know its user, pass . when the below note is showed in start of switch , i'm clicked on pause/break button and the flash of switch initiated and It does not go to the reset password step.  i tested the following button when the switch is coming up:
1.ctrl+C
2.ctrl+B
3.ctrl+break
4.esc
but the switch dont go to the reset password environment.  I even connected an external keyboard to the laptop, but still the switch does not go to the password reset environment
What should I do?
Volgash
Hi @chpmotry
Which terminal emulator do you use? Use PuTTY, or if you are using PuTTY, try using SecureCRT. Also, I have the same hardware in my lab, and I can give you an accurate answer on Monday morning.
Best.
Please mark this as helpful or solution accepted to help others
Hello @chpmotry ,
see the following link for break sequences for various operating systems and terminal emulation software:
https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/12818-61.html
If the no service password-recovery command, after you press the BREAK sequence, the switch will prompt you to reset to factory defaults.
Hope this helps.
Regards, LG
*** Please Rate All Helpful Responses ***
