RestConf curl Tacacs authentication failing
joeharb
Level 5
Level 5
We are testing some curl commands again an ASR router that utilizes TACACS (ISE) for authentication and authentications are failing.  We can ssh using the same creds to the device without issue.
We have tried multiple variations of --user "username:password", --user username:password ...etc and we see the proper username in the failed ISE logs.
Joe
16 Replies 16
hard to say what the problem is here. The AAA looks a bit different as the example below:
https://developer.cisco.com/docs/standard-network-devices/#!ios-xe-aaa-integration-with-netconf-and-restconf/xconf-aaa
JamesMathis
I abandoned using cURL and switched to using an HTTP client in our SOAR and it now works.  I am good with that.  I am still having issues with the API call itself.  I will ask for help with that in another conversation. Thanks everyone for you assistance and feedback.  It is appreciated.  Joe we can mark this one as solved.
