RME 4.0.3. - automated Config Fetch and PIX problem
m.mojas
I noticed something in RME 4.0.3.
In RME > Tools > Syslog > Automated Actions there is system-defined automated action which is called Config Fetch. It collects configuration when it receives one of defined syslog mesasages. For PIX it tracks 111005 syslog message. When that message appears in syslog, RME starts collection of configuration using the following procedure:
It connects to the PIX using telnet/ssh and issues following commands:
conf t
no pager
exit
pager lines 0
disable
In log we can see this messages:
111007: Begin configuration: 192.168.201.202 reading from terminal
111008: User 'enable_15' executed the 'configure t' command.
111008: User 'enable_15' executed the 'no pager' command.
111005: 192.168.201.202 end configuration: OK
111008: User 'enable_15' executed the 'pager lines 0' command.
502103: User priv level changed: Uname: enable_1 From: 15 To: 1
111008: User 'enable_15' executed the 'disable' command.
With that procedure RME starts infinite loop of collecting configurations from PIX - it collects configuration by modifing configuration which initiates another collection of configuration and so on.....
Can somebody tell me if there is a way to change procedure for collecting configutation from the PIX? Or is there any other way in which that can be solved?
Regards!
smahbub
Level 6
Level 6
If you are using PIX running version 7, then you might be hitting the bug CSCsc15519.
