RME 4.0 get config FWSM system execution space
vanbon
We are able to configure RME 4.0 (LMS 2.5) to save our FWSM virtual firewall contexts configurations with “Archive Management”.
But we are not able to save the configuration of the “system execution space”.
Does anybody known if it is possible to automatically save this configuration too ?
Thanks, Gerard van Bon
a-vazquez
Level 6
Level 6
There is no method of saving the configurations of every context defined on the FWSM from the system execution space other than changing to each context to save the config.
