01-16-2006 06:45 AM
I tried to collect Software from a cat 6506 and get follow message:
Processing Device : device_name
Start Time : Mon Jan 16 14:41:14 MET 2006
Device is locked for exclusive access.
The supported protocols for image transfer are: TFTP
Importing the image s72033-pk9sv-mz.122-18.SXD4.bin from the device sup-bootflash into the Software Repository.
Image will be copied to rep_sw1137418884258 using TFTP.
Could not import s72033-pk9sv-mz.122-18.SXD4.bin from the device.
Error Message:
SWIM1124: Failed to copy the image from Flash due to the reason - copyInvalidServerAddress :invalid server address specified.
Retry the operation. If the problem persists, check the Bug Toolkit application for any known issues on the running image version.
Device Import Result : Failed
End Time:Mon Jan 16 14:47:50 MET 2006
SWIM0036: Could not add this image to software repository.
Import of s72033-pk9sv-mz.122-18.SXD4.bin from device failed
No action will be performed to add the image to the library.
Job Ended At : Mon Jan 16 14:49:24 MET 2006
any idea?
thanks
hr
01-20-2006 01:02 PM
try changing the protocol order from TFTP to RCP as the first option(if rcp is supported), this had worked in a similar issue.
01-24-2006 01:34 AM
thanks.
we made an upgrade to lms 2.5.1. now it is working for the cat 6506.
regards
hr
