RME - ConfigMgmtServer unable to connect CM0051
i.cristian
Hi to all
We have a problem with the config management in the RME that we can not sync configuration. When we try to sync de config or try to create a job we get the CM0051 error.
The exact error is:
"CM0051 Unable to connect to ConfigMgmtSever process Cause: Read timed out/Error in received response null Action: Please restart ConfigMgmtSever process. "
Please help...
In the attach i will put:
- pdshow.txt
- ConfigMgmtServer.log
- dcmaservice.zip
The problem was with ctmregistry corruption.
In order to fix it, we need to delete two files:
  1. NMSROOT\MDC\tomcat\webapps\rme\WEB-INF\lib\ctmregistry
  2. NMSROOT\MDC\tomcat\webapps\rme\WEB-INF\lib\ctmregistry.backup
and restart the daemons
7 Replies 7
Svetlana Radzevich
The ConfigMgmtServer is down:
Process= ConfigMgmtServer
    State  = Administrator has shut down this server
    Pid    = 0
    RC     = 0
    Signo  = 0
    Start  = 1/18/2011 5:36:00 PM
    Stop   = 1/18/2011 5:36:16 PM
    Core   = Not applicable
    Info   = Server started by admin request
Try to start it from CLI:
     pdexec ConfigMgmtServer
Hi Svetlana
We did try this but nothing happened ....still no start.
Stillwe found that 2 jar files are missing and maybe this could be a probleme.
The missing jar files are
mdc/tomcat/webapps/rme/web-inf/lib/jdk.jar and jms1.02.b.jar
Is it a Solaris box?
Was it worked before? If yes, what did you change before you notice the issue?
it is a windows installation
yes it worked.....and we did not change anything before.
We just wanted to have an update on the configs
Cristian
The problem is not solved....it reapeared...please see the TAC case.
The cause of the problem was the IPS Manager Express program installed on the same server.
There was some port conflicts between services of the 2 programs (LMS and IPS Manager)
