09-23-2007 05:46 PM
hi,
anyone know which device package i need to load for rme to save archive for asa 5520.i saw the rme4.0 device package but there is not 5520,there is only 5510 and others.is it the same? can i use asa.rme40.v4.0 for 5520 as well. thanks for your reply.
Solved! Go to Solution.
09-24-2007 05:29 AM
The package you are referring to is for RME 4.1
The ASA 5520 is supported in RME 4.0.5 though (dev pkg ASA.RME40.v2-0.zip):
09-24-2007 05:29 AM
